跳转到主内容
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 个问题 查看全部
Axis show on screen when touch shows where the X&Y axis meet.
The problem is that at the top of the screen it shows the following:P:0/1 dX:0.0 dY:0.0 Xv:0.0 Yv:0.0 Prs:0.21 size:0.19 . Also when you touch your screen two lines appear showing where they meet . When you swipe it draws all the points if meets in the x&y axis.. How to repair this problem ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
See Muthu's 2 similar answers below.
完成的
添加一条评论
5个答案
最有帮助的答案
Simple Solution
Go to Settings - System Setting - Developer Option - select off
Pointer will be close
Thanks & Regards
M.Muthu
这个答案有帮助吗?
得分 3
1条评论:
My settings menu is not straightforward, and file transfer requires the developer menu, but turning Developer Option off made the "feature" go away. Now I can stop uninstalling suspect programs. Thanks!
完成的
添加一条评论
The digitizer touch display can be enabled or disabled using developer mode.
这个答案有帮助吗?
得分 1
添加一条评论
It seems like it is running in a test mode for tracking the digitizer. Turn off your tablet and then turn it on holding the power button and the volume up button. This should open the boot menu and give you the options of loading the tablet in "Recovery," "Fastboot," and "Normal."
The Recovery menu allows data backups and factory swipes. A factory reset may fix it, but it will also erase everything on your tablet. If you have a data backup, that may be another option to try and fix the problem.
Fastbook allows you to access the internal memory via and flash new image files via PC. Reflashing your image will reset the tablet to factory, as well, but it will allow you to use custom firmwares.
Normal is the normal load. Not much hiding in the name. Maybe you just need to select this option to get it up and running.
Try the different options and post your results. I want to know what happens!
这个答案有帮助吗?
得分 0
添加一条评论
Simple solution
Connect your handset to PC#
Go to USB dubbing connected#
Go to devolper option#
Click on pointer location to off#
Pointer will be close with axis.
Thanks
Bairagi g.r.
这个答案有帮助吗?
得分 0
2条评论:
Thank you so much sir..
完成的
Fixed my issue. Thanks.
完成的
添加一条评论
go to settings, find developer options, scroll down till you find ‘show pointer location.’ select off , problem solve.
这个答案有帮助吗?
得分 0
1条评论:
I do not have a Developer option tab, where else can I find that. Using a Galaxy Tab A.
完成的
添加一条评论
添加你的答案
Manuel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 43
总计 6,403
