跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1232 个问题 查看全部
I've just got finish replacing my screen
I replaced the screen on my iPhone 5c and all I see is a black screen and white lines going down the left side of my screen.I can still turn my phone on and off but when I turn it off I don't see the "slide to power off" or the Apple logo when I turn it on. I just see white lines. Also, I looked at my digitizer and my LCD cable and they look completely fine. I also hear the snap when im connecting them to the logic board. So, I have no idea what can be wrong with it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Can anyone help me or tell me what they think the problem could be.
完成的
添加一条评论
4个答案
已选择的解决方案
kobe, something like that
can be caused by a bad digitizer connector
like this. Check the ends of the connector. The plastic of the connector has been compressed into the connector, causing it to flare out and preventing from making proper contact.
这个答案有帮助吗?
得分 1
添加一条评论
It could be a faulty display order a new display and fit it and see it it works.
When you switch the phone on can you still call the phone and it rings?
这个答案有帮助吗?
得分 0
添加一条评论
Possibly the LCD flex ribbon connector is the problem, check if it's dirty or damaged. Or you'll have to buy a new replacement.
这个答案有帮助吗?
得分 0
添加一条评论
These guys are right---bad displays are really common. You'll have to rule that out first before looking for board damage which can also cause this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kobe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 124
