Why is only half of the screen displaying a picture?
After turning on the device it only shows parts of the screen why?
If only half of the screen is showing a picture, the LCD display is most likely either poorly wired or burnt out. That means if re-wiring doesn't fix the problem, then you will most likely need to replace the display.
这个答案有帮助吗?
这个答案有帮助吗?
Zack, you didn't happen to cut and paste this answer from someone else did you?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 195
