跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
142 个问题 查看全部
My Hitachi 500 GB hard disk is dead...Can it be repaired?
My hitachi 500 GB hard drive is dead. It does not respond when power is given. I have all my childhood memories in there. can it be repaired? There was some smoke came out of it when i tried to check it. and also it got a kind of a hole in its one chip, please help my email id is pardeep0598@gmail.com ..........please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Sadly there is little you can do here.
If you can locate an second exact same model and size of your hard drive and you have the skills to carefully remove the logic board from the good drive to place on the bad drive you might be lucky. If you do get it working make a backup ASAP as it may not last.
OK, no luck in finding a second drive to swap the parts out. Your last option here is sending your drive to a data recovery service so they can try to recover your data. I must warn you it will be expensive!
这个答案有帮助吗?
得分 2
2条评论:
Thanks Dan For the suggestion and how much will it cost for data recovery?
完成的
Best to goggle your self to find one closest to you. Try: data recovery services
完成的
添加一条评论
添加你的答案
Pardeep Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,420
