跳转到主内容
This children's learning tablet was manufactured in 2013. It has a black exterior, and has a medium sized X on the back. Model number: XO-780. No factory recalls.
8 个问题 查看全部
Why isn't my tablet turning on?
I pushed the power button and nothing happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
my USB/charge port is loose. I know why it won't turn on. I need to know how to get it repaired.
完成的
y is not truinng on
完成的
I push the power button and it doesnt come on.
完成的
Why my vivitar tablet wont turn on
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @randolphmora123,
Does the tablet show that it is charging when you connect the charger to it?
What % of charge is the battery icon showing when you try to charge the battery only and not switch on the tablet?
If it shows that it is charging allow it to fully charge and then try turning it on.
If it still won’t turn on after it is fully charged, can you start and use the tablet with the charger connected and switched on?
If so, then the battery may be faulty and needs to be replaced.
这个答案有帮助吗?
得分 2
添加一条评论
For more information about your XO Tablet please go to the following website: http://xotablet.com/
Also, you can check out the troubleshooting page for this device!
Vivitar XO 7 Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Braanah Craig 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,936
