跳转到主内容
Released in February 2012, by model number DSC-H55
7 个问题 查看全部
Why are my image colors not correct?
Each time I take a photo, my pictures do not look correct. The image colors are completely wrong.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
The Sony Cyber-shot DSC-H55 has several different setting options. If a photo is taken using the wrong setting, the image can be effected. Before taking a photo make sure you are using the right settings. Many of the settings options depend on the background where the photo takes place. Keep in mind that the lighting in the background has a significant impact on the outcome of the photo. If you are taking a photo on a sunny day, make sure the setting used corresponds. If you are taking a photo on a dull rainy day, make sure the appropriate setting is being used. The Cyber-shot also contains an auto setting that may come in handy to those who do not have as much knowledge with cameras. The auto white balance setting can be used to automatically adjust the lighting to help maintain accurate image colors.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Jazmin Young 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 112
