跳转到主内容
This Kodak camera model was released in August 2009. It comes in a variety of colors, and the device allows you to view your photos on a three inch color LCD.
3 个问题 查看全部
Why will my battery not charge?
I have plugged in the camera and left in on the charger for a few hours. However, the charging light will not come in while its plugged in, and the camera will still not power on after being plugged into the wall after a few hours.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
where can I buy a new battery for my Kodak Easy Share 2730 camera
完成的
添加一条评论
2个答案
已选择的解决方案
Make sure that you have properly installed the battery and that it is clean making for good conductivity. The battery might also be dysfunctional, requiring you to have to replace the battery. Your charger may be damaged or be the wrong type of charger causing it not to function properly. Assess which of these might be the issue and pursue remedial action. You may have to buy a new charger or simply have mixed it up with another one you might have. Another common issue is not with the camera system itself but with the outlet you plug it into. Try another outlet to see if it is a dysfunctional outlet and not the battery or charging cords that is the issue. For further information refer to the following links:
Kodak Easyshare M381 Troubleshooting
这个答案有帮助吗?
得分 7
3条评论:
I have tried two chargers, but neither one charges the battery. Does it possibly need new battery? thank you
完成的
I have this problem but the battery is absolutely new. Only bought the camera this morning but the charging light won't come on at all.
完成的
I have the same problem, camera has only been used once since new.
完成的
添加一条评论
I had this problem until I used 2 Duracell Batteries, 14 year old Kodak Camera works fine now
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christina Hamby 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 36
过去 30 天: 147
总计 12,490
