跳转到主内容
联想手机维修指南。
284 个问题 查看全部
Why my lenovo vibe x s960 camera cannot open?
camera lenovo vibe x s960 problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 21
1条评论
what this is factory kit help
完成的
添加一条评论
6个答案
最有帮助的答案
GO to settings - apps - find camera app and clear the data and default and cache
这个答案有帮助吗?
得分 2
5条评论:
But there's no recorded to my default that's why I can't clear it..
My front cam. Is not working please help me..
完成的
heyitsmejra,
i believe your are experiencing hardware fault. remove and reinstall the camera module and check whether it working otherwise you may have to replace a new camera module
完成的
may i know how to reinstall the camera? i also having same problem, suddenly the camera unable to connect. help me pls.
完成的
Help me please... Me already do all of that , and already update the system, still can't use camera help me
完成的
Rixson Frack, You may have to replace the camera
完成的
添加一条评论
My front camera of Lenovo vibe x doesn't work, i want to know if there is any way to fix it or enable it
这个答案有帮助吗?
得分 1
1条评论:
me too. have your front camera been fix??
完成的
添加一条评论
camera depan tiba tiba hilang . s960
这个答案有帮助吗?
得分 1
添加一条评论
Unable to connect to the camera
Update (02/19/2016)
Uunable to connect to the camera
这个答案有帮助吗?
得分 0
添加一条评论
I also have 'Cant connect to camera' on my S960, and I tried different software things with cache, another camera app install, etc. Nothing solved the problem. After that, I've done full software reset to the factory settings. That also didn't help. After a month or so, when I decided to go to the service, I tried full reset again, and my camera problem dissappear!! Now it's working perfectly, and my phone battery last longer than before (I don't know is this related with camera..)
这个答案有帮助吗?
得分 0
1条评论:
How did you full reset???
完成的
添加一条评论
I mean factory reset.
https://support.lenovo.com/us/en/documen...
这个答案有帮助吗?
得分 0
1条评论:
factory kit test
完成的
添加一条评论
添加你的答案
Muhd Kamil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,141
