The engine cover is cracked, will this affect the performance?
I dropped my hammer on my engine and now the cover is cracked exposing the engine parts. Is this bad for the engine?
The plastic cover on the top of the engine is mostly for appearances, so if it is cracked it should not be a problem. However, the middle section of the cover is designed to act as a small filter so that big items do not get in the engine, so if this portion of the cover is completely broken, you may want to think about replacing it.
这个答案有帮助吗?
Only the corner is cracked so I'm guessing I'm fine. Thank you Mr. Wirtz.
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 6,736
2条评论
Do you mean the top plastic cover, or the metal cover over the engine?
由 Tim Wirtz 完成的
I meant the plastic cover.
由 Taichi Nakahara 完成的
