跳转到主内容
Briggs & Stratton 190cc Model 120000 Quantum 675 Series Lawn Mower Engine. Released February 2011. For Toro 6.75 ft-lb torque Lawn Mower.
Why won't my pull cord retract?
I tried to start my lawn mower and my pull cord remained extended after I tried to pull it. How can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Try spraying WD-40 in the mechanism. You may be able to do it without taking it off the mower. It fixed mine'
完成的
Hi I have same issue but its when I put the screws back that hold the Assy down it stops working but if I take off it works flawlessly any idea
完成的
Same issue as Jay hICKMAN
完成的
添加一条评论
2个答案
已选择的解决方案
Try jerking the cord a little harder a few times and it might retract again. If that doesn't work, please look at our pull cord replacement guide. See if you can find out where it might be stuck to have it retract again. If that is not possible then please follow our pull cord replacement guide and replace the pull cord completely.
这个答案有帮助吗?
得分 4
2条评论:
cord will retract when not on mower but when installed will not retract after pulled
完成的
I have the same issue, I picked up the Cub cadet from a friend of mine. This mower is brand new no oil in the engine. It appears that something quite heavy fell on it
So I disassembled it and I'm in the process of replacing all the damaged parts. The pull cord assembly is just one of the parts. Its a brand new part.
It will work fine until I put the screws in it and tighten it down. I can pry it away from the back of the mower and it frees up.
Any idea what might be going on with it
完成的
添加一条评论
It is also possible that the pull cord assembly is broken or jammed. You should take the assembly out and see whats causing the resistance.
这个答案有帮助吗?
得分 3
7条评论:
I don't know how to take the assembly out. If I have to take it to lawnmower experts to sort out, is it costly?
完成的
Where can I buy a pull cord kit?
完成的
None of these answers help me with my problem. I have a brand new rip cord assembly which works perfectly when it’s off of the mower, as soon as I install it, the cord will not retract. What next???
完成的
I have the same issue. New recoil which works when it is not installed. Once installed the cord will not retract.
完成的
sAME, ONLY WORKS WHEN NOT ON THE LAWNMOWER
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Tim Wirtz 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 76
总计 71,510
