跳转到主内容
The first generation Audi A4 debuted in October 1994. The 1995-2001 A4 was built on the Volkswagen B5 platform.
6 个问题 查看全部
Window in left front door lowers but can't be raised?
Audi A4 1994 left front door window goes perfectly down but cannot be closed any more. Possible there is a wire broken in the rubber tube behind door and car body. But there are a lot of wires there. Anyone known to this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Well what I realised on my 97 Audi Cabriolet V6 after spending hours trying to close window I opened on evening I bought car..
I narrowed it down to the MAIN switch control in drivers door. So i unclipped each button from the main controller switch on drivers side off and just changed them around.. i.e.. So rear window switches actually controls front and visa versa..
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem and what I found was if you put your key in the driver door, turn key to lock position and hold in lock position until the window rolls up
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 941
