How do I fix the lens cap error?
There is a lens cap error asking to remove the lens cap even though the it is already off.
My camera got stuck on “turn off, remove lens cap.” Error mode, so i tried the forcibly hitting camera by dropping it to carpet floor about 2-3 times (soft surface) and immediately removed error! Thanks!
这个答案有帮助吗?
I had the same problem, so what I did was to tap he side of the camera couple of times and switch on the camera. It might not work first time, but it cleared the error message
这个答案有帮助吗?
Thank you Robert! I placed a book on a countertop and hit the camera forcibly against the book approximately 20 times and it worked eventually. I tired to hit all sides of the camera. It cleared the error message. All fixed now!
Here are some possible ways to fix this problem based off of relevant researches,
1) There could be some dirt, sand, or small materials blocking the way for the lens to extend so you would need to take a microfiber cloth and clean as much as possible around the lends barrel. Another way could be to forcibly blow out any obstructions around the lens barrel.
2) Turn the power off remove batteries and wait one minute then replace the batteries with a brand new set, once this is complete turn the camera back on while holding the functions button (the ok button). Should that not work turn camera back off and remove memory card and repeat the process.
3) Plug in the AV (audio/video) cable, the reason so is because this will provide more power for the camera lens to extend and refocus
4) Placing the camera on a hard surface, face the lens towards the ceiling, and hold the shutter button while you press the power button. The idea for this process is to try realigning the lens back into their personal slots.
For more information click here to Refer to the troubleshooting page.
这个答案有帮助吗?
Thanks. That worked for me
Followed the instructions and still got the same result with the message stating remove the cover
这个答案有帮助吗?
How do I fix lens cap error
这个答案有帮助吗?
You have to turn your camera off and take the lens cap off then turn it back on.
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 79
总计 20,533
2条评论
My lens is locked in the fully extended position, I also get the lens cap error.
由 Bernard 完成的
mine is in the full zoom position and I get the lens cap error is there any way of fixing it?
由 CZ Channel 完成的
