跳转到主内容
Clothes dryer repair and support guides.
747 个问题 查看全部
Kenmore 70 series electric dryer only runs for 10 minutes
Hello there I honestly have no idea if anyone else has had this problem but I am sure someone has. I have a Kenmore 70 series electric dryer that on a good day will only run for 10 minutes then shut down. During those minutes the dryer does heat. It also does not matter what type of cycle I run it on I cannot get it to run for more than 10 minutes. After sitting for various amounts of time it will restart but only for another 10 minutes. I have only done thisa few times for troubleshooting because I haves feeling I am just causing more damage to the unit. On a bad day my dryer will not run at all. Also after the dryer rests I always have to hold the power button for several seconds longer than I ever used to. Unfortunately I cannot see the specific model number without completely rearranging my laundry room (but I will get it if completely necessary). Hopefully I've covered everything you need to know to get me some answers. Thanks for your help---Brandon
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Brandon, it he dryer motor shuts off during the cycle, it could be the timer and/or the motor. The timer supplies 120 V to the motor and internal on the motor is an overload that could be opening up and shutting off the motor. When the motor shuts off but you can not restart it right away I would check the motor. Also check the faulty door switch or the door may not be latching correctly. You also want to check the vent and make sure there is no obstruction. The only other thing I would recommend to check are the high limit thermostat and the cycling thermostat. Either one may shut your dryer down as the temperature gets over its set point.
这个答案有帮助吗?
得分 2
2条评论:
I have what sounds like the exact same problem. Except mine will run for about 15-18 minutes before shutting off. I've already checked the vent for obstructions and the door latch - both seem fine.
完成的
It might be that the motor it self is overheating and will shut down the dryer until it cools down if this is the case check that the motor itself isn't clogged with lint or that the motor is going out with shaft play
完成的
添加一条评论
Let the dryer cool down and start in “Air Dry” mode (no heat), if it keeps running normally, it means the problem comes from either the heating element or the thermostat.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 31
过去 30 天: 127
总计 9,033
