跳转到主内容
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 个问题 查看全部
How to change my tablet charching port.
because, when i try to charcge it it won't work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
2个答案
最有帮助的答案
There is a possibility that it may not be the charging port, but a bad battery. If it is the battery, you have to replace it with a new one. Please use our guide on how to replace the battery:
Asus MeMO Pad HD 7 Battery Replacement
If it is the charging port that is defective, you must follow our guide on how to detach the motherboard:
Asus MeMO Pad HD 7 Motherboard Replacement
Once you remove the motherboard, you are going to have to remove the solder at the four soldering points that keeps the charging port in contact with the motherboard. With your new charging port, you must solder it using the four soldering points on the motherboard.
If you do not want to solder the charging port off and solder a new one in its place, we recommend buying a whole new motherboard. Luckily, we sell the motherboard on iFixit:
ASUS MeMO Pad HD 7 Motherboard
ASUS MeMO Pad HD 7 Motherboard图片
产品
$29.99
Asus MeMO Pad HD 7 Battery图片
指南
难度:
简单
15 minutes
Asus MeMO Pad HD 7 Motherboard图片
指南
难度:
中等
这个答案有帮助吗?
得分 2
2条评论:
Related to this answer/scenario, would replacing the whole motherboard be equivalent to resetting the tablet? In other words, is the device memory included on the board such that replacing it would be a clean slate? Thanks!
完成的
Yes it is, it's basically like getting a brand new tablet so you will need to reinstall all of your apps and you will lose anything that you haven't backed up. Anything saved to your memory card will be fine as you can just swap that across.
完成的
添加一条评论
The the charging port need replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ivan Rafael Ramirez Romero 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 10,449
