iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2993 个问题 查看全部
pry damage solder a wire or replace component
hello all.
i have a iPhone 4s from a customer, it has a some pry damage (he tried to place a new screen)
now i replaced some 0603 and 0402 components.
but this little black block i don't know.
is it possible to solder a wire on the pads ?
or do i have to replace the component, but what component is this ?
thanks in advance
Update
anyone that can tell me if i need to solder a wire or not
thank you
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
roy, we can not see what you see. Post a couple of images with your question. 在已经存在的问题里加入图片 Show us the components you replaced as well as the "little black block"
thanks oldturkey, seems because i was on dutch i couldnt edit my post or place pictures.
thanks
hey Oldturkey,
i posted the pictures, can you tell me if i can solder a wire across or if i need to resolder the component
thanks
can someone tell me
or if you need a differnt picture also tell me
thanks in advance
I never advocate jumpers. I figured the Apple engineers had a plan with all those parts. Replace them with proper components.It is a Zener diode and check st3v3w's schematic for the proper values.
显示更多的1条评论
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
I can't say whether or not it is safe to jump them with a wire but the part is called DZ30 and it has to do with the head phone jack . i belive it has something to do with an external mic.
这个答案有帮助吗?
按维修分数 2
添加一条评论
添加你的答案
roy 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 178
