跳转到主内容
Nokero Window Solar Flashlight model number N400. White plastic, solar panel, suction cup and 3 LED Lights. Also known as Antero Window Solar Flashlight.
3 个问题 查看全部
Why are my flashlight bulbs dim?
When I turn the flashlight on, The LED light bulbs in my solar flashlight are weak or do not give off as much light as they used to.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If all of the LEDs are dim, that is due to a low voltage battery, or an old worn battery. The best course of action for that is to place the flashlight in a window and let it charge, then try testing again. If the LEDs are still dim, I recommend replacing the battery with a new rechargeable battery.
If not all of the LEDs are dim, or the above solutions do not work for your device, check the Nokero N400 Troubleshooting page.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kyle Burwell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 37
总计 1,452
