跳转到主内容
Nokero Window Solar Flashlight model number N400. White plastic, solar panel, suction cup and 3 LED Lights. Also known as Antero Window Solar Flashlight.
3 个问题 查看全部
Why is my flashlight not turning on?
The flashlight will not turn on even when sliding the power switch.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
There are a couple reasons for why the flashlight won't turn on, the most common reason, is the device isn't charged. Try placing the flashlight in the sun for a couple hours and try using the device again. If there is still no charge, try putting in a fresh battery.
If none of these options work, check out the Nokero N400 Troubleshooting page.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle Burwell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 240
