跳转到主内容
Released June 2000, identified by model number QCP-2035, CDMA radios
1 个问题 查看全部
问题已关闭
Why can't I make outgoing calls?
After dialing the number and pressing the call button, the call doesn't go through.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You may be in an area with bad cell reception. In that case look at the upper left hand corner of your screen to check if you have bars. If you have no bars find an area with better reception. If you have good cell reception and still cannot make the call then your antenna may need to be replaced.
If you are having issues with your antenna, here is a link to the Antenna trouble shooting page.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 772
