跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Will not boot, please see my video of the issue.
The screen is replaced, but the issue started some time after that. Have tried to swap battery, charging port and screen, but the issue remains. No obvious damage to the mb. Where should I look further?
Please see video of the issue here, sorry for bad quality, but I think you can see whats going on. Anybody else seen this?
http://mfi.re/watch/fv5oiw365r7vkv1/VID_...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Jan,
Did you try to restore/DFU mode?
I cannot play the video properly so im just asking, does it pop a blue screen just before the bootloop starts again?
这个答案有帮助吗?
得分 1
3条评论:
Forgot to say that I have also tried to restore. And no blue screen, just a blink of black screen before starting over again.
完成的
I watched the video after downloading it, and even though it does not show a blue screen, the "flash" of black on top seems the same.
Could u try removing the shielding over the flex cables from the screen to the mainboard? See if it boots when the shield is not on there and the screws are out.
It might be that u accidently switched one or two of the screws there and damaged the mainboard.
完成的
The shield over the connections was of when I made the video. I have also inspected the holes through a microscope as I did this mistake with swapping screws with a 5s one time. Learned the hard way, took some hours with microscope and soldering to fix it again... :-(
完成的
添加一条评论
添加你的答案
janoi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 104
