跳转到主内容
Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
36 个问题 查看全部
Where can I buy a replacement screen?
I want to replace my cracked screen, but I'm not sure where to start. How do I know which screen to buy, and where can I purchase it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
4条评论
Where can I fix my steppa table screen cracked
完成的
Where can I buy or fix my steppa tablet screen
完成的
hi guys iam from india i want to know about where get my lenevo Y50 screen replacement IPS display (only from india
完成的
I too am looking for a non touch screen for my e431
完成的
添加一条评论
4个答案
已选择的解决方案
Since you have a y50 Touch, replacing your touch panel is going to be quite a headache- not to mention going to cost quite a bit. You probably only broke the touch digitizer and the main LCD unit is probably intact, but as the two are glued together- you're going to have to replace the entire thing.
If you want to preserve your touchscreen functionality, refer to this guide: http://download.lenovo.com/consumer/mobi...
pg.74 on how to replace your touch panel.
And you can buy a replacement panel at this website: http://www.usspareparts.com/lenovo-y5070... which is the stock touch screen or you can buy a Samsung LTN156KL01 providing you can find someone that supplies it.
If you don't care about your touch functionality, you can buy any of the displays Vivian mentioned above- but you have to also buy the LCD Bezel and LCD non-touch cable for your laptop- you can get that off usspareparts.com as well- but it'll probably cost you a fair amount more even with a cheaper display unit. You have to refer to the same lenovo guide to remove the touch panel though and then install the non-touch panel by following the previous non-touch section in reverse.
这个答案有帮助吗?
得分 8
3条评论:
You are the best! i have been looking for an answer for so long. i have a question though. i found this on ebay
http://www.ebay.com/itm/Lenovo-Y50-70-15...
i am wondering if this will work also. for some reason this looks more official because of the Lenovo sign. Also does the stock panel you recommended come complete like this one?
完成的
Hi, I'm from Brazil and it's really difficult to find the screen+touch display, and even the bezel or the cable. It's not possible just to replace the screen without those two parts?
完成的
Hello I have a touch model is it possible for me to replace it with a non touch
Just asking because i read somewhere its not possible because of the 30 pin cable and my laptop has the 40 pin cable
完成的
添加一条评论
Hi fellow Lenovo user,
After extensive research, I have found a relatively credible links. Before I proceed with the links, I would like to display other pertinent information.
What you Need to Know in order to find the Perfect Screen
  1. 30 pin eDPs
  2. Four screws that hold the display in place
What is the Screen works for yoouuuuuuu?
  1. B156HAN01.2
  2. B156HAN01.1
  3. LP156WF4(SP)(B1)
  4. LP156WF4(SP)(D1)
Thanks to these lovely people for providing the information!
Where to Buy?
http://www.ebay.com/itm/NEW-15-6-Full-HD...
http://www.ebay.com/sch/i.html?_odkw=LP1...
http://www.amazon.com/s/ref=nb_sb_noss?u...
http://www.laptopscreen.com/
这个答案有帮助吗?
得分 6
添加一条评论
Do not purchase your replacement screen from Displaysscreen.com! This company is dishonest. I purchased a replacement screen for my Lenovo Y50 laptop on 15 March 2016. When it arrived it had a sticker "Reliability Test Sample" This means that it is NOT NEW. It has probably been used for 100's of hours non-stop before being discarded by the manufacturer. It also flickers on and off regularly! The company claims to be located in Hong Kong (website) but they are actually located at: Liu Wei Room 313, FuYuan Building, NO.460 FanShen Road, BaoAn 45 District,Shenzhen 518000,Guangdong Province, China Tel: 13332992046 They even want YOU to lie when you return their merchandise. They want you to declare the value to be only $20, but they charge you $144USD! Disgraceful in any culture!
这个答案有帮助吗?
得分 2
添加一条评论
The best source for laptop screens is at laptopscreen.com Not only do they have good prices, but they carry a wide variety of screens. They have a good model based replacement screen selector on their site and carry screens for both touch and non-touch Y50-70 models. They also carry replacement digitizer glass. Make sure you specify if your model is touch or not.
If touch, be aware that if only one of the LCD and digitizer is cracked, you will need to be very careful in separating them as it is easy to break the non-broken one in the process. This is best done with a heat gun or heavy duty hair dryer and a lot of patience. You will also need the right kind of adhesive tape to affix the LCD to the back of the digitizer glass.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicholas Hardy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 30,163
