跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Error 27 or 9 with blue screen - can't start
Hello everybody,
I bought an very cheap iPhone 5s with the error discripton "bootloop". Now it's here and I'm not sure what's the error.
If I start the phone, the screen is black but I can see the backlight. If I hang it on the powercharger, I see the Apple logo.
So I decide to restore it with iTunes. iTunes recognizes the phone but I can't restore it. On normal restore I got error 27. iTunes say it's waiting for the phone -> on the iPhone I can see the apple and the progress bar with 0% and around 1 minute later, iTunes show the error 27.
In the dfu mode I got error 9. It's the same. iTunes want to restore the phone -> on the iPhone I see the progress bar with 0% but then I see for 2 seconds an blue screen without any text. The iPhone restart and iTunes show me error 9.
I vacillate between a defective battery or a defective screen.
Can anyone help me?
Update
Hello again, today I opened the phone and definitely it was not opened yet.
At first I removed the screws that covers the screen connectors -> error 9 (restore) and error 27 (update).
Then I disconnected the display, the camera, the gsm antenna and the other connectors near the screen but I got error 9 again. Is it at all possible to restore the phone without connected screen? I tried to find the faulty part.
I can't imagine that the phone is broken without exposure.
At next I want to change the battery.
My PC is definitely ok. I tried to restore my old iPhone 4 and it worked great.
Any other ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
10个答案
最有帮助的答案
Error 9 is most likely main flash memory corruption, it should be repaired offline, currently it is not possible to restore the phone without using a programmer to re-write low-level memory chip data.
这个答案有帮助吗?
得分 4
6条评论:
Thank you
Chip ? Baseband Chipset ? Do you know the code number?
完成的
Main flash memory is not the NAND flash, right? Because if there is an NAND error, there should be a error like here: http://forums.imore.com/iphone-5/279618-... ?
完成的
It is the main NAND.
完成的
Hey Tom, can you give some information or where we can find some? I searched around but found nearly nothing. Only the label number for a 8gb flash for the iPhone 4.
I think it's easier to replace the flash than to programming the faulty flash.
But if there are no new flash memorys to buy, is it possible to program the old flash with the Progskeet programmer for example? http://www.hardstore.com/PROGSKEET-V1-21... This is an multiple programmer for NAND and NOR chips. According to the description it's usable with iphones.
I have no idea how to connect the flash with the programmer. The Board have an USB port but I'm not sure if it's usable or if I have to extract the NAND chip, build in the programmer and back. That will be no problem (I hope). Reflow station are existing.
完成的
Iceberg, either way this is a very difficult repair. If you choose to repair the main flash, special NAND programmers are required to fix the file system offline because iPhone NAND chips are bare memory chips without a controller in it, and I do not know what's the software used to repair the file system. If you choose to replace the chip, you still need to reprogram the serial number, which involves putting the iPhone into factory mode (even lower than DFU, special hardware required). In China these repairs are limited to very advanced private repair labs, requiring special equipment worth a whole crate of iPhones.
完成的
显示更多的1条评论
添加一条评论
This is motherboard damage and you have been conned ..
Blue screen is damaged caused by long screws near the screen connectors and have torn traces
这个答案有帮助吗?
得分 1
2条评论:
The screen looks not been repaired. The iPhone looks also great. No scratches ot similar. I tried to pull up the glas but it seems to stuck. I can't move it up. The blue screen lights up, only if I try to restore it. If I try to turn it on without any connection to the cable, I see the apple logo and then the screen turns black.
完成的
hey i have the same problem can you tell me what to do ?
完成的
添加一条评论
I had error code 9 and blue screen when trying to restore after new screen and battery from water damage. I found a video that said the four screws that hold down the cover for the screen, speaker and front facing camera are different lengths. It said if you put too long of a screw into the bottom right hand hole, it can push on the motherboard and cause the blue screen. They said remove that screw and try with the hole empty. It worked like a charm, I now have a perfectly working iPhone 5S!
Hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
The way it always worked for me was disconnect the screen and everything else from the logic board and turn it on with minimum amount of stuff plugged in ( disconnect anything unnecessary ) do a restore and once the restore is complete then plug everything back.
这个答案有帮助吗?
得分 1
3条评论:
Yes it worked with me if you restore without screen
完成的
Hi, can you be precise by disconnecting everything ?
完成的
Worked like a charm!!
完成的
添加一条评论
Hi same issue here this is not repairable not even Apple themselves have a clue what's caused the hardware issue u might notice Apple logo flashed all of one second then follows blank screen i tried a new battery lcd and also charging port and managed to get phone to show battery charging icon up but would fail to power on its an issue with motherboard I'm afraid
这个答案有帮助吗?
得分 0
添加一条评论
same problem with 2 iphone 5s
any solution??
这个答案有帮助吗?
得分 0
添加一条评论
same problem with iPhone 6
这个答案有帮助吗?
得分 0
添加一条评论
Have you find any solution?
这个答案有帮助吗?
得分 0
添加一条评论
my iphone5s i change screen than coming bule screen and apple logo i make restore make full service now itune logo
这个答案有帮助吗?
得分 0
1条评论:
plz help me my problem
完成的
添加一条评论
Restore Without LCD .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Iceberg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 25,820
