跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
618 个问题 查看全部
white screen on tv
white is to bright to see picture? turn it off and back on picture came back on.Then does it again after a minute or so.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
评论:
wardharold, first what is your TV's model? then explain the "white to bright" a bit more. Does your TV turn white, as in only the backlight is on or can you still make other things out on the screen. The better you describe the symptoms, the greater the chance to get a good answer. Remember we can not see what you see, so we can only go by what you tell us.
完成的
sorry,yes you can see picture,but it`s like you turned brightness up 200%
完成的
完成的
vizio vw46l fhdtv10a is md #
完成的
The VW46LFHDTV10A has an issue with a variable resistor to come of the board. Of course, you want to check all the connections, pay particular attention to the T-con board connectors.
完成的
显示更多的2条评论
添加一条评论
1个回答
my vizio tv turns on, no logo, then shows black screen then slowly turns into a white screen. Please help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wardharold 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 39
总计 7,614
