跳转到主内容
The first of the new generation Nokia devices – the first with a 1080p screen, the first with a quad-core Krait processor
65 个问题 查看全部
Touch not responsive after assembly replacement?
Got the frame lcd digitizer assembly, attatched everything perfectly, no touch. Put the old part that was working, just cracked, and now it doesnt work either. help please???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
the new lcd assembly you got is faulty
这个答案有帮助吗?
得分 1
评论:
but thats the thing, i dont think it is. because when i put the old one that worked back on, it also didnt work
完成的
添加一条评论
Have a look at the connector on the board. If you have tried the old part and that still shows the fault it seems more likely to board level. Have a look under a magnifying glass to see if you can see any damage on the connector. If that looks okay try cleaning the board with some isopropal alcohol. If none of these work it seems to be a board level fault
这个答案有帮助吗?
得分 1
评论:
Thank you i will try that
完成的
添加一条评论
添加你的答案
Austin Harris 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 154
