跳转到主内容
Repair and disassembly resource for the Oculus Rift family of VR devices.
60 个问题 查看全部
问题已关闭
Why isn't my view in the game following my head movement?
When I am playing any game, I move my head to look at the things surrounding me, but the headset thinks that I am still looking forward. The display is working just fine. I simply cannot look around.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is most likely due to a problem with the device tracker. Since your display is working, the wires connecting to the tracker board should be fine, so the problem is the tracker board itself.
I suggest trying to re-calibrate the device first since faulty calibration could cause the tracker to move in the wrong direction. To learn how to calibrate your device, click here.
If your problem still persists after calibrating, you should replace the entire tracker board itself - refer to the Oculus Tracker V2 Board Replacement guide.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 6
总计 187
