How to remove the optical drive
i was wondering if permanently removing the optical drive from the laptop will help its battery life and if any problems will occur if i just take the optical drive out and not put anything there?
Not really going to save you any battery life. It's only active when you insert a CD/DVD disk. The little drain in standby is so little it's not going to help.
If battery life is an issue I would check your systems battery, do you need a new battery? Then look at what apps are running which could be chewing CPU cycles. Of course review your systems settings
Next things I would look into is getting an external battery pack and you might think about changing out your HD for a SSD but that may not be practical.
这个答案有帮助吗?
Dan is correct, the optical drive does not consume much from your battery when not in use. By removing the drive you will create a Frankenstein that allows dust into the electronics through the empty space or need to cover it with a less aesthetically pleasing item than the drive itself. Please tell us more about why you are concerned with battery life.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 183
