跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
问题已关闭
iPhone 5s won't turn on after Camera replacement.
I followed the iFixit camera replacement guide and after I finished it the phone wouldn't turn on. So I changed the camera back to the original. And it still wouldn't turn on. I double checked the steps. And still no luck. Can someone please help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Maybe you forgot to turn the device off. Disconnect the battery and power up again.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your help. I tried what you said with still no luck. I read through the article again and it said if you put the wrong screw in the wrong hole it can cause severe damage to the logic board causing boot disfunction. That's most likely what I've done. After that I made sure the right screws were in there place. And disconnected and reconnected the battery. With trouble still.
完成的
添加一条评论
Have you tried starting it up without the camera plugged in?
else if you have mixed up the screws on the shield which covers the lcd/digitiser/front camera, you could have damaged the traces
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 488
