跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
MacBook Pro shuts down when applying pressure on Case or Keyboard
Hi There,
lately my Macbook Pro turns off when applying little pressure on the area around the trackpad or the Keyboard.
Sometimes it even turns off, when placing it on a table softly or carrying it around.
Stationary it runs smooth and perfect for hours.
Can anyone figure out, what might be the problem?
Thank you so much in advance!,
Lucas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like your battery has swelled. Time for a new battery.
这个答案有帮助吗?
得分 3
2条评论:
Thank you for your answer. Those shutdowns even happen, when the Macbook is plugged in or doesnt this affect the circumstances at all?
完成的
Pressing on the case is compressing things internally. It makes no difference if the system is powered by battery or AC adapter here. I had one user who always typed hard and when he hit the inner keys the system would wink out. After opening the system and loosening things up the problem went away. Only when the bottom case was on did it mess up.
完成的
添加一条评论
添加你的答案
Lucas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,207
