跳转到主内容
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
35 个问题 查看全部
Why isn't the keyboard dock working?
My transformer pad is connected but i cant use the keyboard because it won't pop up i can only use the 'e' and 'l'key. Also sometimes when i connect the keyboard dock the screen freezes and shuts off and wont turn back on again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
I have the same problem. The "c" types in ";" the "x" types in "q" and the space bar doesnt wok. HELP ME
这个答案有帮助吗?
得分 0
1条评论:
same problem. can someone help me pls
完成的
添加一条评论
Make sure you haven't downloaded any alternate keyboards. If you have, disable all but one. Other than that, that's the only thing that helped mine. K0101......
这个答案有帮助吗?
得分 0
添加一条评论
The last couple that I have repaired have had weird keyboard faults and they both turned out to be poor seating in the edge connector under the keyboard. Pull off the four rubber feet and undo the screws. Take out the two visible ones underneath and the three under the silver tab directly beneath the touchpad. Unlock the ribbon edge connector and clean the ribbon contacts.
It may be as simple as that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jennifer Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,022
