How do you get the back cover off?
I would like to remove the back cover do you guys have any instructions on how to accomplish this
On the 10" version, you use a plastic pry tool between the back cover/bezel. They can be a bit still at first. But once you get going, the leverage from pulling it off should help
这个答案有帮助吗?
Charles, I posted instructions and the tool used to remove the back cover on your Galaxy Tab. Check the attached links,instruction and guide and plastic pry tool, Good luck.
这个答案有帮助吗?
Pry it off with a knife
这个答案有帮助吗?
Did it actually work?
Is there Other things that is useful?
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 32,598
