跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1505 个问题 查看全部
问题已关闭
Replaced LCD, still not working
Recently i dropped my iPhone in a bar and cracked the screen. For some reason the LCD wasnt working either so i had assumed that the LCD had broken too. Either way i replaced both the digitizer and the LCD panel. For some reason, this still didnt work when i had plugged it in
I assumed this might be because i removed and replaced the screen once it was still on. Somewhere it suggested removing the battery to reset it, which i did, running the battery first before reopening. but still no avail.
One other point was that the phone cracked (badly) around the top of the lcd, and that the LCD connector comes loose very easily, even when firmly snapped in.
The phone still works fine, the vibrate/ring switch still makes it viabrate and the phone manages to onnect with itunes still.
Any ideas? im considering buying a full front assembly on ebay to see if that works as it might be a faulty display to start with.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Ok so a new LCD seemed to fix it. It slipped right in and clicked into place so luckily there was nothing wrong on the logic board. However this new screen is pretty yellow.
完成的
way to much yellow or the "regular" iPhone 3G yellow problem ??
完成的
添加一条评论
3个回答
Is the screen white (backlight on) or black (backlight off)?
did you try to to reset it ?
press and hold the home and the sleep button at the same time until the phone restarts (will take around 10 seconds(i know that you might see nothing on the screen, but if you do this while it's connected to the computer, you can hear/see it in itunes).
这个答案有帮助吗?
得分 0
评论:
The screen is black, ive never seen it flash white or show anything ever.
Ive reset it quite a few times and still nothing.
完成的
添加一条评论
Open it back up and disconnect the cable labeled 1. Then blow on it or wipe it off and connect it again. Be sure this cable is completely connected. On my iPhone this cable is always a booger and does not want to snap on very well. It took me several tries to connect it properly. When you do get it on there with a responsive snap when you push it down, reset it again and it should work. If it doesn't then its possible you messed something else up, but more likely that the screen is faulty.
Update
My cable #1 will pop open very easily as soon as i open the phone.
It has never popped off when it is closed
you could have just bought a new glass for the front which is less than $10, since (i think) cable 1 connects to the touch screen glass.
这个答案有帮助吗?
得分 0
评论:
ok were getting somewhere. I did this and managed to get it to flash white, then at some point i saw the home screen but inverted or something, the background was white instead of black and everything really streaky. Now that ive set the screen back in it doesnt go white anymore but still the number 1 cable pops out super easy, even when snapped in, im hoping its an issue with the flex cable bit rather than the socket on the logic board. Ive ordered a new full front assembly from ebay hoping this would fix it.
完成的
添加一条评论
It has to do with the glue in the screen
it is yellow before it dries. It will get better in a few days
if it does not, then it has to do with the back light, and you have the worst luck ever
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 4,097
