Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
482 个问题 查看全部
How do I replace clock battery
clock battery may be weak, sometimes resulting in hard starts. battery hasn't been replaced for at least 5 years.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
I have yet to see one of these batteries fail. To test it, have an ethernet internet connection, go under the Apple in the upper left hand corner to System Preferences, Date and Time, set it to automatically sync with Apple. Look to see that it has done so, now uncheck it. Shut down and unplug the machine and ethernet overnight. Now plug it in and boot up. Check the time. If it is OK then your battery is fine. If not let us know to get directions on how to change it.
这个答案有帮助吗?
按维修分数 1
评论:
Mayer, thanks for the answer. What you described happened when it was unplugged overnight and it took several attempts to re boot it. I was told by a reliable source that the battery needed replacement but didn't know how. That,in a nutshell, is why I'm on this site.
添加一条评论
添加你的答案
tim 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 112
