跳转到主内容
Repair information on tablets manufactured by Dell.
103 个问题 查看全部
Screen is cracked but now only half of screen works
So, only in a part is there a crack, but I have problems with the right half of the screen. The left side moves things when I touch it as it should do, but when i go to the left side, nothing. it doesnt work. It looks normal and everything. the screen is pretty clear, but i dont know what to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Haley, you did not tell us which tablet you have. From your description of the symptoms, it sounds like your digitizer has failed because of the crack. It does not matter what side is cracked, it will ruin the continuity of the circuitry in the digitizer. Replace it to repair the function.
这个答案有帮助吗?
得分 3
1条评论:
It is a 8 inch Dell venue 8 3830 tablet
完成的
添加一条评论
添加你的答案
Haley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,003
