跳转到主内容
How fix loose charging port
Loose Charge port on Apple Mac Book Pro
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you give us the last four digits of your serial number so we can correctly identify which model you have.
完成的
2.26 GHz Core 2 Duo (P7550*)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MB990LL/A Model No: A1278 (EMC 2326*)
Subfamily: Mid-2009 13" Model ID: MacBookPro5,5
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 160 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like the mounting screws internally have loosed up. But without some guidance on which model you have I can't offer you more.
Are you up to fixing your own system here? Do you have the needed tools? You may want to start there.
Update
OK, Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2009 DC-In Board Replacement upto Step 2, then look where the MagSafe connector is you should see two screws which holds the connector block (DC-In board).
If the screws are tight, then the whole DC-In Board unit will need to be replaced.
Follow the guide though or you may want to bring it to someone with better skills. This is a bit tricky repair as you need to fully remove the logic board to gain access to the DC-In Board connectors connection to the logic board is underneath.
这个答案有帮助吗?
得分 1
2条评论:
Here's a good source for tools: IFIXIT Store
完成的
Thanks for your response. Last three letters of serial number : 66D
I have no specific tools, apart from a few "Phillips" screwdrivers.
完成的
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 10,698
