跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
549 个问题 查看全部
How to drain gas tank?
craftsman riding mower, water in tank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
A model number would help us help you.
完成的
917276844 that is the model number if you can help today id be really happy we need it runing
完成的
添加一条评论
3个答案
已选择的解决方案
Simple usually. Just look below the tank and before the carb. You should see a clear tube with fuel in it. It will have a pinch type collar on either end. Simply squeeze the tabs of the collar with a pliers,pull the hose free of it's male fitting and let drain into a bottle of some sort.
这个答案有帮助吗?
得分 3
1条评论:
What if it don't have one of those tubes it has water in it we tried to drain it by putting the frount wheels in a skidsteer but results wasn't good
完成的
添加一条评论
Here is a great video on how to do it safely: https://www.youtube.com/watch?v=zCA0Sw8h...
Whenever equipment is sitting unused over several seasons or especially several years, the gas should be drained as it can create a lot of costly damage to the motor.
这个答案有帮助吗?
得分 1
添加一条评论
I just siphon! Then add stabilizer to remainder.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marlene 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 102
过去 30 天: 348
总计 21,784
