跳转到主内容
加入维修社区 - 创建账户
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
PCIe SSD hold down screw size?
Hi!
I'm planning to add a SSD in PCIe slot on my iMac Late 2013 using your instructions.
Everything seems to be bought, I'm almost ready to start except one thing - I don't know the size of a screw which holds the SSD on mother board and I don't know if it exists (I mean - if it exists while there is no SSD in my config)?
Here's a picture SSD hold down screw
What's the length and diameter of this screw? Can I use a drop of silicone sealant instead of a screw?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
This question was migrated from http://meta.ifixit.com/Answers.
完成的
Hi dv1977, I have the same iMac and thinking of SSD upgrade. I do have only HDD, would like to add blade SSD.
Would you mind to tell which model have you used ?
Thanks,
Nikolay
完成的
添加一条评论
2个答案
已选择的解决方案
That appears to be a T5.
这个答案有帮助吗?
得分 1
2条评论:
This "chosen solution" is not a solution at all. It is actually incorrect. According to these two how to videos, it is a T8 screw, that I am still trying to find myself!
https://eshop.macsales.com/installvideos...
iMac Intel 27" EMC 2639 刀片 SSD 替换件
完成的
You are correct it is showing as a T8 which I have never seen as a blade hold down screw.
完成的
添加一条评论
I think this is the screw for the SSD on the Imac
https://www.ebay.com/itm/SSD-Screw-Torx-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dv1977 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 34
总计 1,395
