跳转到主内容
A collection of repairs for on-ear, over-ear and in-ear headphones, earphones and earbuds.
2202 个问题 查看全部
Headset Charging port not working on Beat Studio Wireless 2.0?
Charging port (micro usb) on the headset itself is not working properly.
When i plug it in, the power light turns on and off after a few seconds. Usually when you plug it, the power light blinks. I found out it is dodgy because when i plug and pull it on a certain angle, it charges, but then if i let it go, it stops.
is there a way to fix this? or any replacement parts like a replacement charging port. Is there a tutorial on how to open the headset?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
10个答案
最有帮助的答案
There is a shop called Cyberion in Arundel mills mall that offered to look into it and repair it. They Said it's common in this headset offered to repair it for a reasonable cost. They replaced the micro USB port and everything was in working order after the repair.
这个答案有帮助吗?
得分 3
5条评论:
What's the cost?
完成的
Could you tell me what kind of shop replaced this port for you? I'm having the same problem and don't know where to turn to. Thanks!
完成的
MyCyberion.com
完成的
JoesGE has repaired thousands of these headphones with the charger port issue. We sell the part for $35 https://bit.ly/2wbJtil and do the entire service for $70. https://bit.ly/2IZMI59.
Free shipping both ways if you want to send your Beats to our repair center.
完成的
How do u fix it
完成的
添加一条评论
I found that this problem is not limited to the wire itself.. If it related to the actual port on the headphones becoming loose (wobbly) so movingit left or right makes it make contacts or makes it loose contact. I have tried several wires besides the ones that came wit the beats all with the same result. The problem is the little tiny piece of plastic that the metal pins are set against in the mico USB port on all of the Wireless Studio Beats. It isn't sturdy enough and eventually becomes loose... And for this much money that shuoldn't be happening... The metal pins I am talking about are what is needed to make contact with the pins in the micro usb plug tip on all cables.
这个答案有帮助吗?
得分 1
2条评论:
Did you eventually get this problem solved? I am having the same issue with my headphones too. It is definitely not the charger cable that isn't the problem, it's the actual port on the headphones :/
完成的
If you still need the part or repair feel free to contact our support team. We fix the issue for $70 and sell the part for $35. support@joesge.com. Service: https://bit.ly/2wbJtil. Part: https://bit.ly/2wbJtil.
完成的
添加一条评论
We sell this [ https://www.joesge.com/products/beats-st...|part] for $35 if you want to replace it yourself or if you want to send it in for repair we charge a flat rate of $65 for the entire service including shipping.
这个答案有帮助吗?
得分 1
添加一条评论
I would get a replacement charger. This is just like phone chargers, the cable itself is most probably damaged.
take it to a repair shop and they should be able to have a look for you.
please accept this answer if it has helped.
这个答案有帮助吗?
得分 0
添加一条评论
The answer, in my case, was the cord. One cord i have to anchor in a certain position for it to charge. Others, i just plug in and they work.
这个答案有帮助吗?
得分 0
添加一条评论
Same issue here. Have tried multiple cords and unless I apply positive pressure on the cord towards the center of the device (pushing the connector itself outward from the center) it does not charge. So currently they are about worthless. Luckily I think I still have six months of warranty so they can fix it (this time).
这个答案有帮助吗?
得分 0
添加一条评论
That happened to me, I taped them and they worked, but now I need to get the charging port fixed. I hope this helps, I am very sorry about your beats
这个答案有帮助吗?
得分 0
2条评论:
what do you mean by taped them?
完成的
Did you end up getting a part? If you need one you can buy a port and the correct tape for the muff on our website. https://bit.ly/2wbJtil
完成的
添加一条评论
It’s in Maryland. they can repair it for you via mail if you’re not from around the area. They specialize in computer and phone repairs so beats wireless was a walk in the park for them. W w w. MyCyberion.com is the website to book their Repair inquiries. I didn’t see a spot to select headset repair but I’m sure you can mention it in their “notes” section when you’re booking or inquiring.
Let me know if you need anything else!
这个答案有帮助吗?
得分 0
2条评论:
Ok, the answer their techs gave me was that “wobbling it gives a temporary solution, but the permanent solution is to solder or replace the entire charging port. Cost for repair is worth it considering it’s a $200 to $350 set of headphones”.
完成的
We repair this issue for $70. Checkout our repair site for more details. https://www.joesge.com/pages/repair-serv...
完成的
添加一条评论
Mine will not turn on at all
这个答案有帮助吗?
得分 0
1条评论:
The best thing to do is to check your charger cable first. If the cable is good then the next step would be to check to see if the charger port is loose. If it wont turn on it could be a charger port issue, battery or power board. We fix all Beats related issues. Contact a Ninja for more help. support@joesge.com
完成的
添加一条评论
can’t you pretty much use just about any old type of charger port from like a old obama phone technically ?? uhh, yes. &&^& paying $35.00 for dat $@$*
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marlu tampus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 39,906
