跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
Charging for few minutes but won't turn on.
Hi.
My brother accidentaly got wet my DSL. It won't turn on. The LED turns green for 2-3 seconds, but DS doesn't do anything. When I set it to charge it's charging for 5-10 minutes and then the LED stops glowing. I've bought new battery, but it's not working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
hi
sounds like your motherboard has blown, this can be repaired but it's pretty tricky to do this - you'd be better off buying a second hand motherboard and replacing it
note though that depending on how much water got in there, it may have also waterlogged the screens as well - if that's the case then you'd be better off buying another second hand ds - they're cheap enough on ebay these days
hope that helps
这个答案有帮助吗?
得分 1
1条评论:
Thanks! Yeah, they are pretty cheap. :)
完成的
添加一条评论
Check the F2 fuse to see if its blown
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Denis Bogdan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 196
