跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
问题已关闭
Shift key always on - keyboard replacement didn't work
I just replaced the keyboard in a 2011 MacBook Air due to the shift key always being enabled but that didn't solve the problem.
  • Shift key shows as always pressed
  • Replacing the whole keyboard with a new one didn't help
  • Same problem in single-user mode and the terminal in recovery boot
  • No visible liquid damage
  • USB keyboard works fine
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It turned out to be the chip/daughterboard on the Trackpad.
这个答案有帮助吗?
得分 0
添加一条评论
Too me, this sounds like you may need to have a look under the keyboard itself. Follow this guide to do this:
https://www.youtube.com/watch?v=LCT-CldP...
The above link may work, please accept this answer if it has helped you
这个答案有帮助吗?
得分 0
1条评论:
First line: "I just replaced the keyboard..." = the whole keyboard has been physically replaced with a new one.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 175
