1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
330 个问题 查看全部
MBA power up issue after water exposure.
Hi community,
I spill orange juice on my macbook air and after I clean up a little, it worked a week before it could not powered up and the charging light is not on. So I disassembled it using the guide and clean almost every component with pure ethanol and after this it worked again. And to be noted, there is no corrosive sign on logic board, no burnt.
I used it for 1 hours and put it into sleep as usual. When I got up yesterday. It cannot powered up again.
So I decided to disassemble again and check if there is anywhere with juice that I missing. I cleaned it again and assembled it again. It worked again, like normal, and there are 85% battery left . But today, it stopped working again, can't power up, can't be charged....
INow I am sitting in front of my laptop and wondering what to do next.
I have digital multimeter and can access to any kind of solvent, but do you think using distilled water and pure isopropanol will make much difference? Do I have to immerse it into the solvent or just wipe it?
Any suggestion would be great.
thanks,
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
Yes often the board must be immersed and scrubbed with a soft brush to clean it. However if there's a blown component cleaning will not repair it.
I wonder if the SMC chip is bad… you're sort of going the long way around to accomplish an SMC reset, completely removing then reapplying power.
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
按维修分数 0
评论:
Hi there,
Thank you for your kind reply, I have tried to use soft SMC reset by pressing Shift-Control-Option and power key, but it doesn't help. Now I am looking where the smc chip is on board and try remove it alone and see what will happen.
Just update that after a thorough clean with MilliQ water and propan-2-ol laptop come back to life and now working flawlessly.
添加一条评论
添加你的答案
Jerry 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 116
