跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
on/off button & back camera
On/off button sometime work, but sometime not. I must press hard and hold in order to make it work.
Back camera have difficulty to focus; mostly the time is out of focus.
Would like to know if this is a hardware failure, if if just something that need to be adjusted, or if it need a replacement.
Thanks,
David
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
David,
Just to be on the safe side regarding the back cam, you can try first a hard reboot and if it doesn't help, then a software restore.
But if you ask me, you have for sure 2 unrelated hardware issues:
1/ The audio and power control cable aka power button flat cable aka PMV cable of your iPhone 5 is starting to go bad. Soon it will stop working completely. This is very common for the iPhone 5, so much so that Apple has a program for repairing this issue for free even if your iPhone is more than 1 year old (check the Support section of their website or visit an Apple Store for details and eligibility), provided that your iPhone has not been tempered with before.
You can replace it yourself, but it is a bit of a PIA. Follow this guide. Be extra careful when prying the battery out. Pry only on the outer edge, never on the edge located near the logic board.
2/ The camera is probably defective too, and needs replacing following this guide.
The reasonable thing would be to have Apple replace the PMV cable (if eligible), THEN you replace the camera.
OR you can just go ahead and do both repairs in one go, since if you are replacing the PMV, you would already have gone through all the steps needed to replace the back cam. Look at the 2 guides and you'll see what I mean.
iPhone 5 Audio Control and Power Button Cable图片
产品
iPhone 5 后置摄像头图片
指南
iPhone 5 后置摄像头更换
难度:
中等
45 minutes - 2 hours
指南
iPhone 5 Audio Control and Power Button Cable Replacement
难度:
困难
45 minutes - 3 hours
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 103
