跳转到主内容
Repair guides and support for the first generation Grand Cherokee ZJ, an upscale mid-size SUV built by Chrysler's Jeep division.
48 个问题 查看全部
问题已关闭
rough idle during warm up
so here is my problem their is a small exhaust leak but idont beleive that is the problem once jeep warms up it runssmooth but every once in a while it bucks a little bit at 60 mph after warmed up
im leaning on plugs wirse cap and rotor because it also smells like its running rich even though their is a small exhaust leak near botom of maifold also could be causing a back pressure problem i am not ase cert but do you think my dynos are accurate thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This could be the camshaft sensor, the engine computer, or something else. If it is the computer, newer ones (probably starting in 1996?) you can kind of fix solder joints on and it might fix it, older ones have the main board covered in potting compound and really can't be worked on. Either way you can try to outright replace it. But it might be easier to check the camshaft sensor first. I'm not an expert I will admit, and my Jeep still seems to have issues after replacing both, but these are solutions that have worked for other people.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 369
