跳转到主内容
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 个问题 查看全部
iPad 3 restarts every 3 minutes
Client brings in iPad 3 Wi-Fi with GSM that he tried to reset because it was constantly re-booting. So it came in stuck on activation screen. It fails to activate, displaying that activation server is temporarily unreachable.
I timed it, and exactly every 200 seconds it restarts, starting with what looks like a "grey curtain" being drawn over the screen then boot-looping. When on the activation screen, it charges and holds the charge normally.
I am not sure if I should try a restore, I'm afraid to brick it.
Anyone solved an issue like this before? Or can suggest something to start with?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
please let me know how long your are facing this problem
完成的
It started a few days ago. It was brought to me 36 hours ago. Why?
完成的
How to Fix an iPad That Keeps Restarting
1. Hard reset
Press and hold the Sleep/wake button and the Home button at the same time
Keep holding the buttons for at least 10 seconds
Release the buttons when the Apple logo appears on the screen
2. Upgrade your iOS
完成的
添加一条评论
5个答案
已选择的解决方案
I had same problem 2 weeks ago, I dont know if its related but after i done update for iOS 8.1.2 about an hour later it shut down then booted back up and shut down again and just kept looping. I plugged in the charger but it just kept looping and switching off still so I took charger back out and left it looping till it died completely. By this point i got so frustrated I left it dead for 3 days, I dont know if it matters how long it was left off but I had a brainwave to plug the usb charger into my Wii and left it there for five minute and all of a sudden it woke up to the home screen and its been on ever since. Im no expert but i think leaving it off for a few days actually helped. I imagine if its stuck in a loop Then so too is the clock in which the boot system uses to start up but like i said im no expert but it seemed to work for me thankfully. Ive had similar problem with laptops and desktops stuck on a loop and Believe it or not the bios time showing wrong time and date was a big part of the problem when stuck in a loop. I hope this helps.
这个答案有帮助吗?
得分 0
3条评论:
Not a bad idea, I will open up the iPad to take a look, and incidentally will disconnect the battery and see what happens. May be a discharge will kick it out of boot-loop like it happened with yours.
完成的
I opened up the iPad to examine it. It appears that the touch screen and the battery have been changed. I decided to go the easy way: disconnected the battery, pressed one the power button for 15 seconds (I do this to drain current from laptop circuit, decided to try it on the iPad). Then reconnected the battery, charged the iPad, and it started normally. I was able to activate it and so far it is running well.
完成的
Hey Rany, I have a similar issue wherein the battery had drained out and it was stuck in the loop forever. To get out of the loop I did a hard reset for a lot of time(as suggested in some forums) and it opened up the homescren with 100% charge(if i plug it out of the wall socket it switches off). Now when I decided to reset it from the menu I saw that my wifi is greyed out. I decided to go ahead with the reset anyhow. Now it prompts me to collect to iTunes but I can't without removing it from the powercord and whenever I try to plug it out, it just goes off.
And it restarts every 2- min in a loop.
Loop history:
1) Shows 0% charge
2) 2 seconds later apple logo appears
3) Immediately the homescreen opens up showing 100% battery and prompts me to connect to itunes(I tried connecting it to mac and trying to wake the device up but its of no use,)
Is there a solution to this problem? I would be highly obliged if you can advice me regarding the same.
完成的
添加一条评论
最有帮助的答案
Hi Rany,
Is it recognized by USB in that state? It may be possible to use some kind of third party software like iTools to read the real time log.
This is probably going to be drop damage to the PMIC and it just isn't outputting the right signal :( The only solvable thing that I can think of is just bad battery. If any iDevice fails to receive the input from the battery of the battery temp, and the battery gas gauge--it shuts off.
A failure in these lines can come from the battery itself, or some damage to the board that broke continuity in the line (not on the radar screen if the iPad was unopened prior to the problem)
Side note: check out iFixit meta---I passed your Troubleshooting section idea over there. Apparently we already are doing this!
这个答案有帮助吗?
得分 1
3条评论:
The iPad is charging normally from what I've seen. And holding a charge fairly well. But I'll look into the above carefully on Monday. The iPad stayed in the shop.
I'll also go over the meta ASAP to see that.
Thanks!
完成的
I downloaded iTools. It kept disconnecting every time the iPad restarted.
The iPad looks like it had the battery and touch screen changed. I did not examine the board, since disconnecting and reconnecting the battery kicked it out of the boot loop. Would you do anything more or just wait and see?
完成的
HI, I have similar problem. I have got ipad 3 wifi with gsm, it reboots every couple minutes. I have installed iTools and collected logs. This is part of log:
Aug 22 09:10:07 iPad-Natalia CLTM[23] <Error>: CLTM: Could not get value for 0
Aug 22 09:10:07 iPad-Natalia CLTM[23] <Error>: CLTM: bad BB temp sensor 6: (-2147483648, -2147483648)
Aug 22 09:10:08 iPad-Natalia CLTM[23] <Error>: CLTM: Could not get value for 6
Aug 22 09:10:08 iPad-Natalia CLTM[23] <Error>: CLTM: bad BB temp sensor 2: (-2147483648, -2147483648)
Aug 22 09:10:08 iPad-Natalia CLTM[23] <Error>: CLTM: Could not get value for 2
Aug 22 09:10:08 iPad-Natalia CLTM[23] <Error>: CLTM: bad BB temp sensor 1: (-2147483648, -2147483648)
Aug 22 09:10:08 iPad-Natalia CLTM[23] <Error>: CLTM: Could not get value for 1
Is this related to battery temp sensor which Jessa mentioned above?
Any help is welcome. Tnx in advance
完成的
添加一条评论
in settings - general - about , you see modem firmware and imei?
if not problem is in flex between logic board and modem board
这个答案有帮助吗?
得分 1
1条评论:
What's solution? Am not seeing imei in setting, amd my ipad 3 restart in few min
完成的
添加一条评论
Cannot find who gave me the idea of unplugging my charger and when iPad starts up plug it into the outlet...... It WORKED... STOPPING THE CONSTANT LOOPING!
这个答案有帮助吗?
得分 1
2条评论:
YOOOOO this actually worked WTF... A four year old comment... Thank you!
完成的
it did'nt work for , or maybe i just didn't did it right
完成的
添加一条评论
I’m having the same problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rany 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 50
总计 32,915
