跳转到主内容
TEAC DC-D2831 Digital Compact Hi-Fi System
14 个问题 查看全部
Can't find replacement motor for turntable.
Hi, I have a TEAC Dc-d2831 and I'm having problems with my turn table. When I play a 33 the table spins really slow making the song sound real horrible, sometimes it'll speed up and play good for awhile. Then it'll malfunction again, it's an intermittent problem. I want to say the motor is going out of it, as I did try replacing the turn table drive belt. It's the same result. I've been searching non stop to find the right replacement motor for the turn table but so far I haven't had any luck in finding the correct motor for it. The original is a WEG-530TD-2f but I can't find that particular one anywhere. I did find a generic one on ebay, but they want over $100.00 for it which is not in my price range. Anyways, I saw your repair guide on changing out the turn table motor on the teac DC-d2831 and I was wondering what type of motor you may have used in place of the WEG-530TD-2f?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Some of these intermittent speed problems on turntables are due to the oxidation of the potentiometers that control the speed of the rotation. So if your turntable has a dial to control the rotation speed at 33 and one for 45 then try getting to the pot' under the turntable plinth and try squirting some contact cleaner in there (or better something like DeOxit which will clean and grease). This has worked for me quite a few times on a variety of turntable with erratic speed problems.
It's somethng fairly easy to try before you invest in a new motor (which still wouldn't fix the problem if it was due to oxidized pots).
这个答案有帮助吗?
得分 0
添加一条评论
I think it could be the cut-out switch that turns off the motor when the arm reaches then end of the record.
I by-passed it and that fixed what sounds like the same speed problems for me. An easy enough thing to try and no repercussions or cost if it's not the issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 412
