My Acer Aspire E1-531 suddenly won't power on?
I have an Acer Aspire E1-531. It's only 1.5 years old. Won't power on, lights that used to light when the charger is plugged in, don't light now.
It was working fine then got the 20% battery warning and while plugging in the charger, it powered off and will not power back on. The port for the charger is right next to the power button and I may have been pushing the power button while trying to plug in the charger.
Tried resetting it (took out battery and held power button for 30 secs) and I took it to Office Depot where they tested it with a different charger (with and without the battery in) to no avail.
7条评论
Very nice answer and link Sam. This will really help people for any type of hardware problem with laptop or cleaning dust.
由 Vergo 完成的
i have this same problem.
i m removed battery and try to power on the laptop with bypass via AC adapter,
but system cannot turn on.
please help , can i change charger?,
why the system cannot turn on in bypass mode ?.
thanks..
由 purushothaman poovai 完成的
I am RAJIV From Tamilnadu in India.
I have this same Problem.
thanks..
由 RAJIV GANDHI 完成的
I have an aver aspire one
When I turn it the screen is showing scrambled and snow
Please advise
由 missy 完成的
I have acer aspire E1 ( Z5WE3), I usually remove the battery on it and I work with the ac adapter. from 2 months the labtop didn't turn on exept I replace the battery and after that I can remove it and the labtop can work when keep the ac adapter at the outlet IF I remove the ac adapter from the outlet, I have to replace the battery again to turn the labtop on
I try to hold 30min but no effect, any advice????
thanks
由 Hisham 完成的
显示更多的2条评论
