跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Camera's pictures quality awful after screen replacement
Hello,
I just replaced my wife screen after drop damage. It's one of the easiest phone to fix and replace. everything went back to normal except the image quality are terrible now for rear camera. I don't know what happened! Color, brightness and glare all weird. I checked the housing plate and the lens from inside everything looks in place even ribbons. All I can see there is not good light controlling.
Front camera is giving me natural colors better than the rear, and even nexus 4 rear camera is much better and I easily can tell the different!!!
Any ideas will help is appreciated,
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I have the same problem. Did you ever figure it out?
完成的
添加一条评论
2个答案
The only thing I could suggest is that you may have gotten a smudge on the camera during the repair. I've never seen a camera go bad after a screen replacement unless the camera itself was damaged during the process.
Worst case scenario you'll have to replace that camera specifically. Should only cost a few bucks if you order it online.
这个答案有帮助吗?
得分 0
添加一条评论
No1 mistake, the phone shop you used installed a cheap aftermarket screen and marked up the price
这个答案有帮助吗?
得分 0
1条评论:
Hi J U,
Appreciate your attempts at helping, but perhaps you could focus more on recent, active questions rather than ones that were last responded to eight years ago?
完成的
添加一条评论
添加你的答案
Dan Ramzi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 3,866
