跳转到主内容
The MiP robot was released in August 2014. MiP is an interactive robot toy designed for kids. The robot responds using hand sensory technology, as well as a downloadable app that allows MiP to drive, dance and play games.
11 个问题 查看全部
MIP bluetooth won't discover
Trying to use bluetooth with my iphone 6 and it never FINDS the MIP---just says discovering over and over...Thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
6条评论
How to pair it and is deos'nt register
完成的
Having same issue. Tried replacing batteries, uninstalling/reinstalling app. No success. Entered a ticket on WowWee's website, but no answer yet. Will post when they do. Please update if you find a resolution.
完成的
We had the same problem. We ended up exchanging it for a new one. We knew something was not right when it wouldn't connect to any devices including an iPhone 6. As soon as we turned on the new one - it connected to our son's nexus 7. Looks like the Bluetooth was broken in the original mip.
完成的
Please can someone help me! I need the password for the bluetooth when trying to connect? Any ideas as to what it could be and where i could find it
Thanks
完成的
does bluetooth on? if not do this scroll down
完成的
显示更多的1条评论
添加一条评论
8个答案
已选择的解决方案
Try switching Bluetooth on or off in the Settings and try pressing the refresh button in the top right. As mooka1 said, try tapping on the auto-connect screen.
这个答案有帮助吗?
得分 4
1条评论:
I have an LG k10 and I am haveing the same pobelm
完成的
添加一条评论
if its stuck not the search for mip screen (has the mips jumping up and down on it) tap the screen and you should go through to another screen that allows u to pick a mip.
hope this helps.
这个答案有帮助吗?
得分 3
添加一条评论
The MIP robot is no longer discovered with the Android 8.0 (Oreo) update (bluetooth issue). Already reported to Google.
这个答案有帮助吗?
得分 2
2条评论:
This is correct I have android 8.0 and I was able to connect the mip to the app, but after I had to change the batteries the mip isnt showing up on my phone again. Very frustrating.
完成的
If your mip doesnt turn on with new batteries then there might be a loose wire. I had TO takes the screws out of his back and mess with the wires. There should be a black and red wire (thicker than the other wires) have masking tape on the end of the wires. Tape the wires back to there circuit board and it should turn on
完成的
添加一条评论
What about pie? Not working on Samsung s9 plus
这个答案有帮助吗?
得分 2
添加一条评论
I Can't connect my Mip to my phone. It says I need a passkey but it never said that before. Earlier it connected flawlesly. Please help me find a fix.
这个答案有帮助吗?
得分 2
1条评论:
Yeah me too can someone help . What is the pin?
完成的
添加一条评论
Try switching Bluetooth off and then on a couple of times. If not the try charging the MIP.
这个答案有帮助吗?
得分 1
添加一条评论
It worked just fine on android 5 untill i put new batteries into mip then its not showing on the app it shows the mip in the Bluetooth menu but it needs a
这个答案有帮助吗?
得分 1
添加一条评论
I try connecting to Bluetooth and it asks for a pin
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
publicinfo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 87
总计 31,063
