跳转到主内容
Model A1051 / 4 or 6 GB hard drive
90 个问题 查看全部
How do I replace the HD in an iPod 2G with Flash Memory?
I have both a 4GB and 6GB Gen 2 iPod Mini, one of which appears to have a dead drive. Whether or not that's so, I've heard of people installing 4-8-even 16GB Compact Flash cards (like the Shuffle uses) to replace the hard drives (articles on geektechniques.com and instructables.com).
With the price of 8GB CF cards as low as they are -- you can get a very high-end 8GB SanDisk Extreme III CF card that has 30MB/s sequential read/write speeds for around 50 bucks, and plain old "quick-enough" cards that size for under $20 -- it seems like a Good Thing, Martha.
Anybody have any experience with doing this? Problems? Joys? Any input greatly appreciated!
Thanks
Bart
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
How to turn your iPod mini into a flash based iPod
iPod Mini Remastered with 16 GB
Those should answer your questions :-)
这个答案有帮助吗?
得分 3
添加一条评论
Very easy, provided the only problem is with the hard drive.
Check that your compact flash is formated in "Fat32"
(You will need a USB compact flash reader plugged into your PC to see this)
Check the pin orientation and install.
Perform a "Restore".
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bartbrn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,853
