OK! Here are some pictures of the fix. I wasn't able to find any pictures of the inside of the drive at all when I was doing my initial Google searching so this should be very useful for someone who might have this same issue. To get to the rollers, simply unscrew the four Phillips head screws that hold the gear train assembly in place; the entire assembly should come off.
The piece is basically just a linkage for the two rollers in front so that the rolling action is distributed (only one of the rollers is connected to the rest of the gear train). Without the piece the roller shown on the left wouldn't move, causing more strain on the right one to push the disc out.
It's pretty darn loose fitting and I can see how it might pop out easily if someone grabs the disc while it's coming out or if someone pushes a disc while the PS4 is feeding it in. I just had to pop the left roller out, insert the plastic piece in between, and pop it back in.
Voila!
11条评论
Hello friends. I had a problem with inserting or ejecting a disk from ps4. I opened it as a member from I fix it site explained. Everything was easy. When I opened I was a little confused and I slowly looking inside optical drive to know how it works. I turned it upside down and I saw a white stage thing coming out and then a black gear. I told to myself that I now have to buy a new optical drive because I didn't think that I could fix it. I was wrong. This white thing is to easily reject or insert a disc in ps4. I fixed it . If you don't put it inside you'll have the same problem with me to insert or reject a disc easily from your ps4. The black one with the spring is to manually reject a disc from ps4.
由 Konstantinos 完成的
I can't find my little piece...i opened the ps4 and wasn't there...... Someone please can send me detailed photos of all angles and views of this piece so i can 3d print it?
Please! My e-mail is
guto_1205@hotmail.com
PLEASE
由 gustavodgrs 完成的
i google it some images, but i cant find it anywhere.
由 gustavodgrs 完成的
I just emailed you.
由 TronicsFix 完成的
I need one of the grey rollers - unfortunately I fixed a drive rattle and thought it was one of the grandkids Lego pieces - it may be in the boxes of millions of other pieces but I can't find it. any one willing to sell me one from a junk drive, know where I can order one, or know who manufacturers this drive for Sony? I don't need to pay $30 for an entire assembly.
由 carl rayl 完成的
显示更多的6条评论
