跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
问题已关闭
What is a non-obvious cause for a faulty temperature sensor?
My MacBook Air suffers from intermittent slowdowns and unnecessary fan use. I sent it to Apple under warranty and they replaced the battery and the logic board. But the problem persists and iStats shows that the temperature is reading -128 C.
It seems that Apple was right to replace the logic board which includes the temperature sensor (right?) But, why didn't that fix the problem? It seems very unlikely to have two faulty logic boards, both with bad sensors.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Run ASD, tell me what temperature sensor fails. There are many temperature sensors. One in the trackpad, one on DC in board, ones on the board itself. Sometimes the sensor fails, sometimes the sensor is fine but cannot communicate with the SMC because of bad or missing pullup resistors on a data line, corroded via, corrosion pulling down a data line, or a bad SMC.
这个答案有帮助吗?
得分 1
1条评论:
ASD? Apple System Diagnostics? I get codes PFM006 (fan), PPN001, and NDC001 (camera). Not sure how to to determine which thermal sensor is bad.
完成的
添加一条评论
Louis you're right. Apparently there are also three sensors on the battery. TB0T, TB1T, TB2T.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,768
