Audio but no video
My Mitsubishi TV WD- 60735 has audio but no video after replacing the lamp.
Can you tell me what to look at, I checked my ballast and that is fine.
What else can I check or need to do to get the video?
I am using a cable box without HDMI inputs.
Thanks!
Michelle, just for clarification. Why did you change the lamp? did you have the same issues with your TV before you changed the lamp or is this a new finding? Do you have any error code coming from the front LED Indicators?
The front panel LEDs provide an indication of the set’s operation, and the possible cause of a malfunction. There are three
front panel LEDs, “Power”, “Status” and “Lamp”. The LED display shows the current status or indicates a possible
malfunction.
由 oldturkey03 完成的
Get the shutdown error code-
Make sure lamp, lamp door, back cover, etc is installed properly.
Plug in TV.
After TV initializes press power to turn it on.
The TV should try to turn on a few times then shutdown with the red light.
Go up to the front panel on the TV, press and hold MENU + DEVICE (INPUT) until a light on the front starts blinking a two digit code like 3 blinks pause 4 blinks repeat or similar. Let us know what you find.
由 oldturkey03 完成的
Oldturkey03, first let me say thank you for replying to my question.
I change the lamp because I was getting a failed lamp code (I forgot what it was but the lamp was bad)
I am no longer getting any red or yellow codes after I changed the lamp and it stays on.
I get a steady green light (status) The TV turns on and off normally by either the remote or the front panels.
I went ahead and press the menu and input key to see if I would get an error code and the only thing that occurred
was 1 green blink and then 2 green blinks. TV stayed on.
Does this help?
Thanks again.
由 Michelle 完成的
I gave you the wrong green light, the light that stays on until I turn off the TV is the Timer light, the status and lamp light are not lit.
When I had the lamp problem I believe it was Red. Don't remember now but I do know the error code pointed to the lamp being bad.
由 Michelle 完成的
I guess you know already that I can't see the setup screen to change anything as well but I thought I would mention it.
由 Michelle 完成的
